hey all, our previous IT guy was a power mad control freak and set passwords on all of our network printers![]()
then he left....
now nobody can access these printers to adjust the settings
can anybody tell me how to reset or even better, delete the passwords for a Lexmark C762 and an HP LaserJet 4100 MFP???
I've checked both company's web sites and come up with nothing...
any help would be greatly appreciated.
TIA!!!!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
you have to log on with the password to get to the menu with that option.....
Almost every networkable device I've seen has some sort of button combination or "pinhole" on the device to hard reset these settings. Obviously if you forget the password, a menu option behind the password isn't much help !
Google or the manuals or a phone call to the manufacturer would be my next port of call.If in doubt, Google it. -
Are you talking about some type of software server off of a central computer, or are these printers network capable themselves?
If it's software, you'll have to uninstall (and I mean comopletely obliterate it, registry, etc.) and re-install. This is a weird setup, but I've seen it before. Very shoddy.
If they're network capable, simply do as jim suggested.
If they're connected to a separate print server (not a PC), it should have the same type of reset/default setting button
Also, after about 5 seconds of searching, I found this. -
We've got a couple of JetDirect Print Servers and I've needed to use that guide a few times since it is impossible to tell the IP, subnet and gateway to first be able to crossover to the print server to change settings. Easy to just restore factory defaults. Works well.Originally Posted by Supreme2kIf in doubt, Google it.
Opera passwords
By jollyjohn in forum ComputerReplies: 2Last Post: 25th Sep 2011, 03:54 -
Resetting ffdshow
By PERSHON in forum Newbie / General discussionsReplies: 17Last Post: 11th Mar 2011, 14:23 -
FF not saving passwords
By jollyjohn in forum ComputerReplies: 6Last Post: 26th Sep 2009, 09:53 -
Resetting PC?!
By Squid_uk in forum ComputerReplies: 30Last Post: 15th Apr 2008, 18:45 -
FYI: 'free' GMAIL ARCHIVER steals passwords?!?
By ahhaa in forum ComputerReplies: 2Last Post: 12th Mar 2008, 10:49
