Hi. To convert from Divix or Xvid to DVD I use Diko with CCE SP and Softencode. I was just trying to convert a dual audio track (english and french) Divx movie to DVD. The video was fine but I got only one track made out of distortion.
I'm not exactly skilled in this area so any detailed help would be greatly appreciated.
Try using Virtualdubmod to strip out both tracks as uncompressed wav files, then encode each seperately using softencode. Add them back in at authoring time.
Read my blog here.
I imagined that it would have something to do with Virtualdub. Would you happen to know where I could get a step by step guide describing the procedure?
i'd recommend using virtualdubmod as well, except for stripping them out in wav, id just demux them and use them in whatever format they are in...or if absolutely nessacery, convert directly from that format to whatever format you need...no need to decompress to wav..... as for a guide on how to do it, just use the search button or check in guides section......
Here is a link to extracting uncompressed WAV files with VirtualDubMOD. Nice guide easy to follow.
https://www.videohelp.com/forum/viewtopic.php?t=280779Wow!
The box said 4 to 6 years, and I put the puzzle
together in 3 weeks.
Can a Divx Compaitable Home DVD Players able to play dual audio?
By paul.1911 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Nov 2010, 12:46 -
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 05:31 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 23:54 -
Program switches audio track priority of dual-audio assets
By PBear in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 16th Nov 2007, 20:36 -
Help extracting language track from dual audio video.
By ebisoba in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 14:53
