Ok, i've got a few DVD's from which i need to get some specific videos and make a compilation in a single disc. after extracting these videos, would you recommend any specific app?
Any specific requirements about how it plays back ? eg:
Do you need a menu ?
Do you want one big clip with chapter points, or are you happy with multiple clips ?
Do all the clips have the same aspect ratio (are they all 16:9 enhanced, or all 4:3) ?
Do they all have the same audio format (eg. all AC3 5.1 or all AC3 2.0) ?
All of these issues will factor into any suggestions.
If you don't need menus, and are happy with multiple titles, then you can do this quickly in DVD Shrink.
If you do need menus, perhaps TDA is a better option.
A few more details will help narrow the field.Read my blog here.
yes, i need a menu that can give acces to multiple clips, all the clips have the same aspect ratio (4:3) and all of them will have the same audio format (ac3 2.0), all suggestions are welcome.
Simplest solution, use DVD Shrink to rip the sections you want to your HDD, use TDA to compile them into a DVD with menu. Shrink is free, TDA has a 30 day fully functioning trial.
There are many ways to skin this cat though.Read my blog here.
Video Compilation
By redcapeman in forum EditingReplies: 4Last Post: 27th Dec 2010, 06:01 -
When Ripping Compilation CD's...
By Nitro89 in forum Off topicReplies: 3Last Post: 1st Nov 2009, 09:48 -
Differing volume levels on compilation video DVD
By mr_tinka in forum Newbie / General discussionsReplies: 15Last Post: 4th Sep 2009, 23:12 -
DVD compilation.
By Benhermies in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2008, 12:46 -
Putting text over a video (making a compilation RATM DVD)
By Salva Veritate in forum EditingReplies: 4Last Post: 1st Sep 2007, 14:52
