Hi Guys,
I'm putting together a DVD for a friend of some footage of their wedding, there are 3 different sources, my DVD Handycam, Mini DV Cam which I have put onto DVD and imported and also a photoslide show converted to MPEG. I have two menus, the second menu has a "Return to Main Menu button but I can not figure out how to link it back to the main menu. I have added a bridge but it only lets me kink to the bridge and not the main menu, I am a bit of a novice but can usually figure things out by messing about but cannot do this one? can anyone offer me some help?
Many Thanks
Ryan
This could be either very simple or very not. Open your project window and tell me if you see any icons in the list labelled VTS2 or just the one labelled VTS1. The only time you'd need a bridge is to link different VTS's.
You've linked all your other buttons to movies without problems right? (You do realize that a choice of menu links are under the choice of movie links?) -
Unfortunately I have to use the different VTS's as they are all different AR's
Just started Work so shall check that out tonight an update.
Linking to the web with DVD Lab Pro 2
By V879 in forum Authoring (DVD)Replies: 6Last Post: 1st May 2011, 10:31 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 16:02 -
[DVD-lab Pro]Links dissapear/ cell linking
By Ninerian in forum Authoring (DVD)Replies: 3Last Post: 24th Oct 2008, 08:11 -
Cell Menus Dvd lab pro
By angelus214 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 10:52 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 19:10
