i have the m2v and the ac3 demuxed from original dvd title. but how to get a TEXT BASED subtitle stream to add to my re-authored dvd project using DvDAuthorGUI ? thanx
"In the case of subtitles, the subtitle dialog box will appear, allowing the user to select a text based subtitle stream. The subtitle options allow the user to custimize the character-set, font size, font face, and anything else that needs to be customized."
Results 1 to 11 of 11
Tam
You rip it from your original DVD with SubRip.
/Mats -
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
tried subrip. but dvdauthorgui gave same error it always does when creating dvd starts...ie, some retarded error about subs being wrong. i'll give vob thingy a try
Tam -
Retarded or not, the error message is probably important. Let me know what it is and I will try to help. As for the readme, it has not been updated to reflect the use of .sup subtitles. As borax suggested, use projectx or something similar to rip the subtitles to .sup format.
hmm, so i can add a .sup into dvdauthorgui with no problems ?
however...
ERR: Unable to open file F:\Program Files\DVDAuthorGUI\sub1-1.d/00+01+12.44.png
WARN: Bad image, skipping line -1
STAT: 0:01:13.680
ERR: Unable to open file F:\Program Files\DVDAuthorGUI\sub1-1.d/00+01+13.68.png
STAT: 0:01:26.560
ERR: Unable to open file F:\Program Files\DVDAuthorGUI\sub1-1.d/00+01+26.56.png
STAT: 0:01:32.680
ERR: Unable to open file F:\Program Files\DVDAuthorGUI\sub1-1.d/00+01+32.68.png
STAT: 0:01:56.080
ERR: Unable to open file F:\Program Files\DVDAuthorGUI\sub1-1.d/00+01+56.08.png
STAT: 0:02:00.480
ERR: Unable to open file F:\Program Files\DVDAuthorGUI\sub1-1.d/00+02+00.48.png
STAT: 0:02:05.600
ERR: Unable to open file F:\Program Files\DVDAuthorGUI\sub1-1.d/00+02+05.60.png
Process aborted due to above error
There was an unknown error. Please review the log for more information.
think i'll give this junk a miss.
been looking @ a thread @ cdfreaks. i have dvdws2, so might give that a try. thanx all the same
Tam -
I don't want to bother you, but would you try my GUI for dvdauthor too? It would be very interesting for me if my sup2png program can deal with this 'problem' sup file...
GUI for dvdauthor:
It should!this is supposed to work.
GUI for dvdauthor:
sorry borax, but your program is way too difficult for me to use. i read the detailed guide, but still, i am a relative beginner. thanx anyway.
Tam
Author AVCHD with simple text-based menu?
By litmus in forum Authoring (Blu-ray)Replies: 1Last Post: 28th Feb 2010, 18:52 -
DVD subtitle to text file
By hardy in forum SubtitleReplies: 3Last Post: 27th Jun 2009, 20:31 -
Split DVD into movie clips based on timing info in subtitle file.
By kwazi in forum Authoring (DVD)Replies: 1Last Post: 20th Feb 2008, 11:27 -
Subtitle issue with DVDAuthorGUI
By GangstaRap in forum Authoring (DVD)Replies: 1Last Post: 11th Feb 2008, 07:37 -
default subtitle and audio commands for DVDAuthorGUI
By ecc in forum Authoring (DVD)Replies: 2Last Post: 21st Dec 2007, 21:06
