I have a Jeep Cherokee with a DVD Entertainment System but it won't play movies that I've downloaded and burned onto a DVD.
Would a DVD hack help solve this.
(PS: I know Ford uses DVD Players made by Audiovox, but I don't know who manufactures them for Chrysler)
Any suggestions would be welcome.
Thanks!
Results 1 to 16 of 16
have you tried using different brand of discs? some players are picky about dvd-r
I am just a worthless liar,
I am just an imbecil -
Have you been bit-setting? That is the only way my laptop will read a burned dvd is as a DVD-Rom. That has worked in everything I've tried them in so far.
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate! -
I have a 2005 dodge minivan that also has a DVD kit from Chrysler in it.
I have been able to play DVD+R and some DVD+RW's in it.
It would not play TDK +RW's but would play older HP +RW's. It took a long time for the player to recognize them, but they did play.
+R's that I have used are TDK, Memorex (Both Ritek & Ricoh based) and HP. I have some Pioneer -R's but it wouldn't touch them.
I saw a reference to the player manufacturer once. I believe that they are made by KOSS, but I could not get an exact model number.
CheersDa MoovyGuy -
Change media;
Confirm whether + or - media required for player; silly question but can be overlooked. You maybe using +'s when infact it should be -'s; or vice versa.
Check the manual that can with vehicle. There should be a manual specific for the entertainment sysytem. Check out the specs, model etc. Possibly do a Google search on model to get more info.
Try burning at MINIMUM speed.
Last one; are discs dirty, greasy fingerprints, scratched etc etc? -
but it won't play movies that I've downloaded and burned onto a DVD."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
That's a thought!!! As per Gadgetguy's comment. Are you sure you encoded to mpeg2 AND authored to VIDEO_TS before burning??
WHAT THE H**LNo DVD can withstand the power of DVDShrink along with AnyDVD! -
These movies could well be legitimate movies, maybe even provided by the car manufacturer. I know that BMW do some damn good short films that are free to download - one is directed by Guy Ritchie.
I certainly hope it is legitimate. No more comments on that, though - if you're going to post, please try only to help. -
Originally Posted by gadgetguy
Originally Posted by otpw1
I have been doing this for almost 2 years and have found this to be AT LEAST as compatible to dvd-r's if not even more so....... which when you have a dvd player that wont play either dvd-r or dvd+r, but will play a dvd+r with the booktype changed to dvd-rom, i guess that would put it above -r in terms of compatibility.....
Originally Posted by jtoolman2000
Even though they are totaly free and legal to do so
and i have some that rival ANY hollywood released dvd in content and special effects 8) -
Thanks to everyone for all the suggestions.
I tried bitsetting and burned as Book Type: DVD-ROM but that still didn't work.
I then switched to DVD-R's (instead of +R's) and these now work in my 2005 Jeep VES DVD Player.
Thanks! -
Thanks for the follow-up.
Reporting back what works is very valuable.
Again
THANKS!!A good divorce beats a bad marriage.
I need to update my previous post... I thought the DVD-R's worked, but I spoke too soon... Only one movie has worked so far, and everything else I've burned onto DVD-R's haven't worked. The only difference has been is the file size... the one that worked was a smaller movie (3.3GB)... the normal size ones haven't (4+GB).
Anyone have anymore suggestions for my 2005 Jeep Cherokee factory DVD player (called VES - Vehicle Entertainment System)? -
Use good media
Read www.nomorecoasters.comWant my help? Ask here! (not via PM!)
This should be my last entry on this topic that I initiated because I'm fairly sure I have found the problem, which is... any PAL movies that I download do not work... only NTSC works... which means i now will have to convert my PAL movies to NTSC (unfortunately it takes a few hours to re-encode them), but at least i've found a way to play them in the Jeep.
BTW... DVD-R, +R, -RW, +RW all work if it's an NTSC encoded movie, and i've tried it with different media (Maxell, Verbatim, Sony). -
It never occured to me you might be using PAL discs. The Jeep should be a region 1 system.
You're quite fortunate that it reads all that media.A good divorce beats a bad marriage.
Burned DVD from TV and won't play in computer
By dnlowe in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Sep 2009, 17:41 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 02:09 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 01:21 -
want to play burned cd in my car
By terrie29 in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2007, 01:55 -
AVI File Burned to DVD won't play ?
By DuBsTaR in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2007, 20:20
