    Nov 2003
    Toronto, Ontario
    Hey All,
    Is there a program out there that batch multiplex's mpeg2's.?. I tried imago program with the batch option written by a user. I was just getting error messages. Tmpgenc has no batch option either. If someone knows, please let me know.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You should be able to find mplex.exe through a web search. From memory it is also included in a couple of GUIs for commandline tools, but I cannot think of an example of where I've seen it.
    Anyway, mplex is used via the commandline, which means that all you need to do is create a batch file with all your commands in it, and let it do it's thing.
    If in doubt, Google it.
    Jul 2003
    Chicago IL
    Sorry to dig up an old thread. I'm using mplex to multiplex several sets of elemental streams together. I use a batch file that has a line for each mpeg that reads something like:
    mplex.exe -f 10 1*.m2v 1*.ac3 -o 1.mpg
    The problem is that I have to have a separate line for each set of elemental streams. Is there a way to do this with a one line batch file using wildcards?
