Hi all got a challenge for you. Not sure whether this should be in dvd to dvdr forum but here goes..
I want to make a 2-3 mins dvd or avi clip by taking multiple clips from various dvds and adding them all together, and including some effects as well if possible. All the dvds are backed up versions so not worried about ripping problems. Is it easier to convert the few seconds from each dvd to avi, then use say winmovie maker to join. i tried to do this with simpledivX but the resulting clip wouldn't play.
Any advise welcomed or further clarification if needed. Any specific programmes i should check out?
Cheers folks
thanks i shall look in to their guides.
I should have said that i dont mind if the final 3mins of clips are in avi format or mpeg. I just thought it would be easier to go from dvd to dvd rather than encode all the small clips individually to avi and then join them. anyway win movie maker doesn;t seem to want to play my avi's, not my xvid encoded ones anyway!
cheers
how can i add multiple video clips to play as one dvd???
By Banleno007 in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2012, 10:53 -
Mac Guy Needs Windows Help Editing Clips, Authoring DVD
By dizzie in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2010, 13:12 -
TMPGEnc convert multiple clips with 29.97 & 25 fps to a dvd
By sychern in forum Video ConversionReplies: 2Last Post: 11th Oct 2008, 16:34 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
Combine multiple DVD clips in Adobe Premiere Pro
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 12:55
