hi,
a buddy of mine was given the task of taking a bunch of single project on different DVD-r's, and putting them together. All the DVD's are unecrypted (projects from a class).
He wants to bring them into FCP, so he can add chapter markers beforing bringing them into DVD SP.....how can he do this with the least amount of quality loss?
Friends don't let friends use Windows!
Elisha Cuthbert is so a total schorchcake!! -
DVDSP can add chapter marks directly to the imported .m2v video files, so best quality will come from ripping the original discs into separate .m2v and .ac3 files, load into DVDSP, add markers and whatever else, and build a new VIDEO_TS folder with these materials.
Unless the new disc is substantially larger than 4.4 GB, there should be no quality loss at all. If it is larger and he has DVD2OneX, he can run the resulting folder through DVD2OneX to squash it down to correct size for a single-layer disc.
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 15:59 -
Making A QT from a dvd to edit in fcp
By wildstrawberry in forum MacReplies: 0Last Post: 10th Oct 2008, 15:13 -
FCP dvd authoring problems
By sksvideo in forum MacReplies: 3Last Post: 18th Mar 2008, 16:57 -
How to burn FCP cut using DVD Studio Pro4?
By dvdude in forum MacReplies: 4Last Post: 8th Mar 2008, 22:12 -
i'm really new, i have no idea what happened with mactheripper: dvd to fcp
By relativist in forum MacReplies: 6Last Post: 5th Oct 2007, 19:41
