    Oct 2005
    Greece
    hi guys i usually try to fix all my problems on my pc alone. thats why thats my first post here. the site helped me a lot and now i m having a prbm that i cannot fix.
    here is the prbm.
    i have installed
    ac3filter_0_70b
    XviD-1.1.-127-13102004
    lame mp3
    some stuff from Nimo50Build9Beta1
    not all. just these i needed
    latest ffdshow
    and avisynth 2.55
    the prbm is when i try to demux ann ac3 sound from an avi.
    File : 1.35 GB (1.35 GB), duration: 1:51:04, type: AVI, 1 audio stream(s), quality: 76 %
    Video : 1.4 GB, 1348 Kbps, 25.0 fps, 640*320 (2.0:1), XVID = XVID Mpeg-4, Supported
    Audio : 305 MB, 384 Kbps, 48000 Hz, 6 channels, 0x2000 = AC3 DVM, Supported
    i demux with VirtualDubMod -->stream-->stream list -->demux
    when demuxing is over the file is not ac3 at all
    its not even a music file.
    AVIcodec and GSpot dont recognise it
    when i drag drop it on TMPGEnc DVD Author 1.6 to make a dvd
    i get this error
    on DVD-lab PRO i get this strange one
    and the final resault from avicodec is this
    File : 305 MB (305 MB), duration: 0:00:00, type: DSH, 1 audio stream(s), quality: 72 %
    Audio : 305 MB, 384 Kbps, 48000 Hz, 6 channels, 0x1 = MS PCM, Supported
    here i must say that the same prbm is with all my avi vids with ac3 sound.
    i allreaddy have reinstall all codecs ffdshow and everything 3 times
    hope someone can help me.
    the prbm started when i first removed my codecs and i reistalled them cause
    Subtitle Workshop
    wasnt loading my avi files.
    all strange prbms hapened to me
    ps after dvdlabpro "fixed the ac3" the file lost 1 kb only
    Apr 2004
    Miskatonic U
    And did it load ?
    You could also try AC3fix to repair the headers. Basically, it looks like a poorly encoded or subsequently corrupted AC3 audio track. If it can't be repaired, then there isn't much you can do. The hazards of downloading.
    Read my blog here.
    Dec 2004
    Australia
    I'd suggest AVIMuxGUI for demuxing.
    You downloaded a codec pack because you wanted AVISynth and ffdshow?
    AVISynth download: http://www.sourceforge.net/projects/avisynth2/
    Info on new ffdshow builds (mine and others): http://forum.doom9.org/showthread.php?t=98600&goto=lastpost
    Oct 2005
    Greece
    how does avi mux demux the audio only?
    can you give me a link for that?
    and the codec pack i installed it for other stuff not ffdshow and or avisynth
    guns1inger And did it load ? You could also try AC3fix to repair the headers. Basically, it looks like a poorly encoded or subsequently corrupted AC3 audio track. If it can't be repaired, then there isn't much you can do. The hazards of downloading.
    i hust want my ac3s to come out ok not with prbm and then fixing the prbm.
