with dvdlab
can you play a sound when a button is selected in the menu?
thanks all!!
I cant really see too much there?
does that mean I would create a clone menu but with the sound I wanted in the in the cloned menu and at the end of the menu it goes directly to the selected movie?........I make no sense I'll keep browsing the forums
thanks -
DVD menus aren't like web pages or computer programs (OK, they are like computer programs, but really simple ones). You can't just do a mouse click type event in them, The spec doesn't allow for it. If you sit down and really watch commercial disks, you will see that they don't really do it, either. What you have to do is create either a new menu page, or a small video clip, that plays when you select an option. It is the only way it can be done, whether you like it or not.
Read my blog here.
quick question about the file browser in DVDLab Pro
By YOURCONNEXX in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2010, 18:16 -
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 19:04 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 17:47 -
DVDlab menu question
By rizay in forum Authoring (DVD)Replies: 3Last Post: 12th Dec 2007, 09:54 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 05:55
