goog pc-tv card was recommended. I tried and it would not work. It brought system to 100% resources. No tech support info came with it. I thought I found their site and asked. I got no reply. I tried again several times, but never again found their site. Shop recommended to reinstall my xp pro. I did so and got the same 100% resources when I ran the goog.
Do you have any recommendations as to why or what other card I can try.
I so wanna record TV onto my HDD. I really do not even care about watching TV on the pc. My plan is to burn DVDs.
Tks,
Paul
Please provide more information. What card are you using to capture, with what connectors, what software, and what are your system specs.
Rob -
capture card: goog pc-tv
connectors: What? Do you mean my air antenna?
software: that came with the goog
system specs: 1.3 gig AMD, 300 meg ram, over 50 gig free HDD, dialup -
Try here looks like the OEM supplier for the Card.
http://www.lifeview.com/usa/html/products/OEM/oem-googe.htm -
Look at LISTS>Capture Cards on the left of your screen.Click on "rating" to show the best rated capture cards by users and pick one you can afford.
For software I use VirtualDub for capture to AVI(Very good tool,recommended) and WinDVR for MPEG capture.~Luke~ -
For capturing from any source, I would recommend more free hd space (ideally you should have a dedicated hd for data only), and at least 512mb of ram.Originally Posted by paulmarsRob
HDMI device that can capture (unencrypted) "HD" audio sources?
By jalyst in forum Capturing and VCRReplies: 70Last Post: 28th Mar 2017, 14:45 -
VHS tape capture "flickering" - Intensity Pro Capture Card
By mofaster in forum Capturing and VCRReplies: 2Last Post: 31st May 2009, 13:56 -
Need help...Newbie who's just bought "EasyCap" USB Capture Device
By RICHM0802 in forum Capturing and VCRReplies: 1Last Post: 19th Sep 2008, 02:18 -
Auto-split 10 hr capture in 3 min chunks "on the fly"
By atvmxr in forum Capturing and VCRReplies: 2Last Post: 22nd Apr 2008, 10:48 -
someone suggest screen capture software to make a "movie"
By graysky in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 06:08
