  1. Okay, I have a bunch of .VOB files that I want to be playable on DVD. I'm sure this has been answered before but when I put it on a DVD I think it only makes them as DATA files and they are not playable on a DVD player. I've searched this site and used some articles but it still only works when played on my computer. Anything I should know?
    What happened to the .IFO file? Is it still present?
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Are the VOB files part all 1 continuous clip split up, or is each VOB a different clip ?
    If in doubt, Google it.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    TMPGEnc DVD Author will accept the vob's and let you author and burn a new DVD with them.
