I'm using tmpgenc xpress 3.0 and when I encode and video it takes up to 8hrs to convert no matter how big of a file it is. Is there any settings to change to pick up the process a little. Thanx All.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters - -
If no filters etc being selected then check that it is NOT on VBR (2pass) is it? That will double the encoding time as it analyses first. Make sure nothing else is hogging your RAM; Make sure 'Preview' option is unticked in Xpress. Be aware that Xpress is very slow anyway. TMPGenc Plus is still best IMO; slow (Xpress slower) but good; doesn't look as pretty but still good. Damn TMPGenc Plus is just GOOD!!! LOL. Consider doing a batch encode and then go to bed!!!! All done in the morning-maybe!!!
Switching from 2-pass VBR to 1-pass Constant Quality will double your speed. But it's hard to control the file size. 1-pass Constant Bitrate is just as fast and is easy to control for file size, but you'll have to use high bitrates.
The other major setting that has a big effect on conversion time is Motion Search Precision. -
I use "Estimate", good and fairly fast (relatively).Originally Posted by junkmalle"Art is making something out of nothing and selling it." - Frank Zappa
Xvid4PSP 6.001 encoding options?
By vampypiano in forum Video ConversionReplies: 3Last Post: 10th Nov 2011, 14:54 -
bd rebuilder encoding options question
By kronick in forum Blu-ray RippingReplies: 0Last Post: 3rd Jul 2011, 12:21 -
No encoding options in XMedia Recode
By thezanny in forum Video ConversionReplies: 2Last Post: 26th Apr 2011, 08:02 -
encoding .m2ts with Megui. What's the best options?
By badreligionhead in forum Video ConversionReplies: 4Last Post: 23rd Sep 2009, 16:24 -
AutoGK encoding options
By MyBigToe in forum DVD RippingReplies: 2Last Post: 3rd Mar 2008, 12:47
