I'm looking for A Low Profile Hardware (Mpeg) Capture card, Must have Video out. Most sites I looked at Dont say or have any Pictures of the Card.
Can Be PCI or AGP.
Thanks,![]()
Results 1 to 12 of 12
www.hauppauge.com
The Hauppauge WinTV-PVR-350 is an excellent hardware PCI MPEG-2 encoding card. It has a video out, but it only works on standard MPEG files, no DVD or AVI for example... -
What is "low profile" supposed to mean?
I don't think they make one for ML@LP if that's what you're after. Most consumer cards are strictly for MP@ML for DVD.Want my help? Ask here! (not via PM!)
This is a Low profile CardOriginally Posted by lordsmurf
It's going into a media case "Small".
Hi there,
Have you checked Newegg? A quick peek there shows quite a few cards that are low profile. They have pictures for just about all of what they sell.
I personally like my ATI theatre elite card, I think it is a low profile card, but can't honestly remember. But it don't got video out.
I think that there are a few of the Hauppauge MCE edition cards that are low profile that may have video out. -
Probably not. Video cards need a lot of room for all the parts. It's not a wimpy modem or something.
I agree. The point of a video card is to provide good quality picture, and you just need room for the parts if you want good quality. You might find small external ones though, I think I saw something at Fry's that just looked like some cables and then a box the size of a mini-cell-phone. It was a capture card though. I don't know how good it would be.Originally Posted by lordsmurf
Just get an external (ADS PYRO AV/LINK). All you need is a firewire connection. You can get the AV/Link with Adobe Premiere Elements for around $160.00, and you can use it on multiple pc's, move it from place to place, etc...
Rob -
What look for is the Hauppauge WinTV-PVR-150 I.p. but should be take note that Low profiles card don't always come with half size PCI backplate.
unfortunately, i don't think there are any true low profile cards...well, I haven't came accross any...t might have to be trial and error to see what fits...my AIW 9600 BARELY fit inside my small form factor case.
The is a low profile version of the Hauppauge PVR-150. See the picture:
http://www.newegg.com/Product/Product.asp?Item=N82E16815116629
The PVR-150 has lots of problems with PAL but seems to be OK for NTSC.
seeking 2 low profile brackets for diamond/ati tv Wonder HELP?
By bearcor in forum Capturing and VCRReplies: 1Last Post: 10th Oct 2010, 10:00 -
Low profile capture card options
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 30th Mar 2010, 18:59 -
Very good roof antenna for HDTV that is very low profile ?
By Seeker47 in forum DVB / IPTVReplies: 13Last Post: 21st Aug 2009, 02:20 -
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 14:39 -
Card with mpeg-2 hardware capturing for standard definition?
By Giantsloth in forum Capturing and VCRReplies: 3Last Post: 27th Oct 2008, 19:26
