I have this movie that is XviD and AC3 sound. I can't play the movie and it works fine with the picture showing and sound playing but when I got to VirtualDub it shows that the ausio stream is unknown. I have included a pic showing what I mean. When I try to decode the audio stream to standard PCM vitualdub tells me it can't find a decoder to do so. I have tried AC3 Filter so far and virtualdub still shows the audio stream as unknown. Can anyone point to me a AC3 codec that won't do this in virtualdub? Thx
allyourbasearebelongtous
Try the AC3 ACM Decompressor in the tools section. Install then reboot. VDub will then play your file.
It doesn't matter who you vote for. The government always gets in.
Installing 32bit AAC ACM and AC3 ACD codec on Windows 7
By pchan in forum Software PlayingReplies: 3Last Post: 26th Apr 2012, 15:53 -
Wrong Codec ??? (for DTS to AC3 conversion) Please help!
By KushSmoka420 in forum AudioReplies: 4Last Post: 29th Dec 2011, 08:50 -
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 16:42 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 18:47 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 18:57
