I have 43 VCD's with videos on them.. IS there anyway to combine all those to fewer VCD's? maybe dvd format? right now they are in .DAT files...
Thanks,
Chaz.
Convert them to DVD files. All you have to change is the audio rate, from 44k to 48K. You can even use a trick to leave them at 44K and still play them in most settop players.
Look to the left under 'Convert' and search for 'VCD to DVD' conversions. -
Each VCD had about 20 videos on them. if i convert them to DVD how many out of 43 VCD's do you think i cant crunch down to?
thanks again. -
Simple maths could give you rough estimate assuming each CD is full... roughly 700Mb per Cd give or take, 43 CDs multiply and divide result by 4,500Mb odd the capacity of a DVD
only rough i know but will give you a ball park figure
HTH -
Here's how I would do it:
Extract the MPEGs out of the DAT files using VCDGear. Drop the MPEGs into TMPGEnc DVD Author, which will upsample the audio from 44.1KHz to 48KHz on the fly. Burn the result.
There's also a sticky on the topic here:
Can I burn VCD or SVCD on DVD±R/W?
You can normally get around 6 VCDs on a DVD, so assuming each VCD is full, you should be able to get the whole lot on around 6-7 DVDs.If in doubt, Google it.
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 09:25 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52 -
Some video files and movie files won't play
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 21st Feb 2008, 11:08 -
Can I Put Video Files And Picture Files On Same Disc?
By Lennoxtown in forum Video ConversionReplies: 3Last Post: 29th Dec 2007, 07:05 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 04:24
