im trying to extract a wav file from an avi using vdub, but im only gettin about 1.12hrs of it...when the movie is about 1.58hrs
is there any programs i can use to get a wav from an avi flie instead of vdub or dbpoweramp??
Years ago, someone made a great freeware WAV editor called Diligence Encounter97 you can still find it here:
http://wuarchive.wustl.edu/systems/ibmpc/win95/miscutil/enc97b5.zip
might be worth a shot.
Later
baz
Why don't you simply load your avi into Premiere? You will have then a sound track, which you can save as a wav file or, depending on your plug-ins, an mpg file.
DVD to AVI or WAV
By GarrettKooper in forum DVD RippingReplies: 2Last Post: 5th Aug 2010, 17:25 -
Is There a Free Program that Removes Hiss and Pops from WAV files?
By cplevel42 in forum AudioReplies: 10Last Post: 24th Nov 2009, 13:28 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
cannot extract wav from AVI
By ecc in forum AudioReplies: 3Last Post: 22nd Jul 2008, 18:21 -
Best program to convert Audio Cassette Tape to WAV
By jimcornetet in forum AudioReplies: 8Last Post: 14th May 2007, 15:48
