I have ripped successfully! But every time I go to frameserve with the DVD2AVI, I go thru the motions in the guide and get stuck with a monster BLUE window that says "The parental settings on this player prohibits play" and has a "yes" & "no" box. Clicking either one of those does not do anything at all! It just stares at me, taunting me!!! This happens right after I have seen my file list with all the vob's and select "ok". Then, the evil blue monster! What the hell is this?
I checked to see if I have the correct file, the tmpgenc vfapi plug-in by downloading it again, then checking properties. It is there alright! Are you suppose to be able to open it? Because the icon looks like a turned down paper with a window on it. This has GOT to be the problem! Please tell me again how to do that "install.bat" thing! I don't think it has been done correctly. Aaaaugh!
Thank you for stopping a nervous break down,
Tracey
<font size=-1>[ This Message was edited by: thump01 on 2001-12-23 02:53:24 ]</font>
Tracey-SAn make sure you have the corect version of Vfapi plugin for TMPGEnc and all you do is double click and it will be registered then you have to copy DVD2AVI.vfp to TMPGEnc'directory and that should do it and Tracey-SAN what version of DVD2AVI are you useing
and oh yea make sure the vfapi plugin in in the same directory has TMPGenc okay....and Happy Holidays Tracey-SAn
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 10:44 -
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 07:40 -
Vegas Pro 9.0 (64bit) won't see installed Filter/Plug-In
By mltwitz in forum EditingReplies: 1Last Post: 26th Aug 2010, 14:16 -
VFAPI and Windows 7 64 Bit
By JekhoOne in forum Video ConversionReplies: 3Last Post: 21st Apr 2010, 14:56 -
VFAPI aspect ratio change
By Weapon-X in forum EditingReplies: 1Last Post: 5th Mar 2008, 16:28
