i have a Samsung DVD-V440 DVD-VCR combo, which is DivX registered.
As it cannot display heb subtitles, i add the subtitles permanently to avi files, using TMPGEnc and VobSub https://www.videohelp.com/forum/userguides/153058.php .
For Video compression i use either DivX or XVid formats, for sound mp3 format.
This plays great on my PC. however, on my Samsung player there is no sound when playing the avi files.
What can i do? Should i use other formats, or do anything different?
Thanks 4 your answers
Kim
Results 1 to 11 of 11
vbr mp3 is not included in divx certification-should be abr or cbr mp3.Originally Posted by just_kim_usa
I don't know about your player but most don't like very low bitrate MP3. Don't go below 96 kbps.
320 kbps may be too high for the audio! I recommend you try short segments with different settings on a RW disk until you get your problems sorted out.
I use VirtualDubMPEG2, and VirtualDubMod for creating Xvid AVI files. -
Hello Kim
Divx and Xvid files created with TMPGenc do not have interleaved audio. To play back on a DVD player, the audio must be interleaved.
Use VirtualDub to make the files and be sure the 'Audio Interleaving' is checked. The reason is explained in the VirtualDub Help file under Audio Interleaving.
If you want to correct your file made with TMPGEnc then use VirtualDub and select Direct Stream Copy for both video and audio. Make sure the Audio interleaving is checked. No loss in PQ and very fast.
Hope this helps,
Chas -
That would explain why the audio doesn't play on a Divx/DVD player. DVD players can't seek fast enough to get audio and video chunks from different areas of the file.Originally Posted by Megahurts
AMAZING - IT WORKS!!!
Took your advice and started adding permanent subtitles using VirtualDub (newbies: guide here https://www.videohelp.com/forum/viewtopic.php?t=272736 )
easy to use, works like magic using original audio stream.
i salute you, my kings
Kim
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Why does this mpg file doesn't play sound in my divx player?
By Stealth3si in forum Newbie / General discussionsReplies: 15Last Post: 5th Jul 2009, 20:00 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Is there a difference between a Divx player and a Divx certified player?
By Hank Kinsley in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2007, 13:30
