    Mar 2003
    Fargo, ND
    Hey all,
    I find the slideshow feature of Movie Studio missing a feature that I really need (or maybe what I'm trying to do isn't technically a "slideshow").
    I need to have a series of pages that the user clicks through using their chapter Next and chapter Prev buttons - i.e., a "manual" slideshow. The reason for this is that I have a little 30-question trivia quiz that I want them to be able to go through - one slide is the question, next is the answer, question, answer, etc. Obviously I want them to go through at their own pace.
    I know this is pretty common on studio-made dvds because this is how they do picture galleries and scripts, etc., so I'm sure it's nothing terribly difficult.
    Anyone point me in the obvious direction?
    Thanks,
    Sped
    Edit: I think the feature described may be called "stills gallery" - thanks.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If you are looking for what I am looking for...I haven't found it either. I want each photo in my slideshows to read as a "chapter"...never found that button on my software either...
    Mar 2003
    Fargo, ND
    After doing some more searching for this feature, I'm beginning to think that we're not alone in our quest. Seems like none of the standard packages have this option...
    I suppose it could be done with just creating a series of menus and use the navigation buttons instead of the chapter buttons (which, come to think of it, is how the commerical DVDs do it anyway).
    Sounds like a lot of manual work though....
  4. Originally Posted by hech54
    DVD Architect has this,It will Auto make Chapters for every Picture.
    (Picture Compilation)
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Great....now I know what you are buying me for Christmas...
  6. If no continuous sound is required, it is possible with a lot of DVD authoring programms. Just create the 'slideshow' as menu pages... Then it is even possible (but only with quite flexible authoring programms) to have different 'slides' shown after a 'correct' or a 'wrong' answer.
