probably does but why the hell am I even asking this question?![]()
Results 1 to 14 of 14
Depends on what you mean by 'wireless'. Some KBs use infared and have to be pointed at the IR receiver. Some use radio signals and then the receiving antenna has to be close enough to work. You may also get more radio interference or noise within a car.
Plan on doing some encoding during the morning commute? -
Right if the reciever is in distance and the signal can reach yes.
Kinda like the wireless keyboard/track combo that I found that one time when I wanted to put a computer in my car.
http://www.mp3car.com/ -
In Dash computer
7" Monitor
Now if the computer could just learn to drive correctly. -
I'm working on a carPC for my truck.
I am just a worthless liar,
I am just an imbecil -
I just had a brain drain as I thought that with the car moving the signal would be stationary but it would obviously reach the PC due it travelling at very high speeds compared to the car
I was thinking of using a cordless mouse but having my laptop in the boot with a few TFT's monitors within the car
those black car pc's are awesome (the one linked it discontinued) and I was wondering when I would see them. It will soon be a lot cheaper and easier to buy stuff that that for your car 8)
http://www.xenarc.com/product/mp-sc3.html
http://www.xenarc.com/product/mp-fl8.html
mackemx i'm not sure i understood that, but check this site out. i think they have carPC's...
http://www.mp3car.com/I am just a worthless liar,
I had an idea of using my old laptop in the boot (trunk) with a couple of 7" or so TFT monitors. I'd then just have the cordless mouse for whoever wants to use the PC
. It was just a daft idea but if I can get car pc stuff in the UK then I'll look into it
those systems above have to be showing as the CD is within the unit. My ideal system would be something like the CD player I have now but with the removable faceplate like most car stereos. That would obviously that would be accesed by the PC which would be tucked safetly away elsewhere via say a USB cable
that means the PC unit wouldn't have to be restricted to the size of those above and may offer better spec possibilities
thanls for the link and I can see that pic has something like a CD slot but can you get stuff like what I described now? -
i think right now the closest you'll come is to mount a slot-loading dvd drive in the dash
Originally Posted by TooLFooL
as the less on show the better for me
Originally Posted by e404pnf
though I wouldn't mind the electrical pimping side of it
Good Long Range Wireless Keyboard/Mouse Solution
By greymalkin in forum ComputerReplies: 3Last Post: 1st Apr 2012, 18:49 -
can anyone recommend a wireless keyboard and mouse combo?
By mrgain in forum ComputerReplies: 3Last Post: 15th Jul 2009, 11:00 -
PS/2 or USB for mouse & keyboard?
By Xylob the Destroyer in forum ComputerReplies: 11Last Post: 9th Feb 2008, 10:23 -
Are you using padding or cushioning devices with your keyboard/mouse?
By yoda313 in forum PollsReplies: 9Last Post: 16th Jul 2007, 15:59 -
Mouse/Keyboard dose not work after coming out of Standby or hibernation
By noki in forum ComputerReplies: 13Last Post: 7th Jun 2007, 09:00
