  1. is there another program apart from winavi and dvxtodvd as winavi is quick but it uses lots of memory and as for divxtodvd well its not a memory hog but takes for ever to convert a avi movie to vob files
    Apr 2004
    Miskatonic U
    What's forever ? I can convert a 90 minute avi in around 70 minutes, and my PC is no powerhouse. Compared to 4 hours for a full encode, that is pretty good.
    Read my blog here.
  3. guns1inger: for ever= ages a long while so what program do u use then
    Apr 2004
    Miskatonic U
    Usually I don't mind taking the time, so I will frameserve from avisynth or virtualdub, using correct resize and sharpening filters, then encode with a 2-pass VBR. It runs overnight and takes around 6 - 8 hours.
    If I wan't something done in a hurry, then DivxtoDVD. Like I said, better than real-time is good enough.
    How long does it take on your machine, and what do you think it should take ?
    Read my blog here.
    Apr 2003
    Maryland
    I for one use VSO DivxToDVD. I can load a 60 minute tutorial Divx file and have a working DVD in about 70 minutes.
    What do you consider "forever" as I could not make heads or tails of your equation
    "For ever= ages a long while so what program do u use then"
    It should not take more that almost 1:1 real time.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  6. I for one use VSO DivxToDVD. I can load a 60 minute tutorial Divx file and have a working DVD in about 70 minutes.
    well i use same as you vso divxtodvd when i try to convert a 700mb .avi movie its nearly like 1 and a half hours
    Yes, but the quality is excellent and, once you click the "Convert" button, it's not like you have to nursemaid it along, right? Get a cup of coffee and watch the news.
