I only want to export only a portion of my project from the timeline. I'm sure it's very simple, but how?? I've tried online help plus my old Premiere 6.0 manual to no avail. I've tried to define a work area by setting in and out points, but it wants to export the entire project--also tried markers but same result. I'm sure it's very simple but how??? Help!!! Thanks in advance.
wwaag
wwaag,
Under export settings, there are two options: export entire timeline and export work area. Make sure that you export the work area. -
I've done just that--selected work area. Bottom line--how do you define the work area??
Finally figured it out. Pretty simple "once" you know how to do it. Thanks again.
wwaag
Super Easy Question about COMPRESSION USING ADOBE PREMIERE PRO CS5
By BronProductions in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2012, 19:48 -
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 19:51 -
Question about Premiere Pro's aspect ratio math
By Asterra in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2011, 09:15 -
premiere pro rendering question
By thecrock in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2009, 17:30 -
Adobe Premiere Pro 2.0 project file/autosave question
By wwervd316 in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2008, 20:14
