Hello to the forum this is my first post, I hope thjat the information I am giving is not too vague. I am a begineer at this DVD burning lark so please excuse my ignorance on the matter
Anyway, I have bought an LG GSA-4163B DVD Writer I have burnt 3 films onto some memorex 8x DVD-R in DVD video format.
They play fine in the Pc on the LG DVD drive, but when I try to play them in my stadalone DVD player (ALBA DVD50XI) all I get is bad disc/incorrect fdvd format messages.
I have hacked the ALBA DVD to be multiplayer, so it cant be that causing it.
Has anyone got any suggestions?
I would really appreciate anyone more learned than me offering some tips!
I don't see an Alba DVD50XI in the list of DVD Players on this website, but there is one AlbaDVD5xxx on the list (DVD59) that doesn't play DVD-R. Are you sure yours will play DVD-R? Has it played other DVD-R disks?
Hi there, thanks for the reply.
I have only used dvd-R as in my ignorance I purchased these disks, not knowing any different!
I guess I should try a DVD+R then?
I dont know if the ALBA plays DVD-R, I have only used pre recorded commercial DVDs in the past, what format would they be in?
Thanks. -
Pre=recorded comercial DVDs are neither DVD +R or -R. DVD +R and -R are designated only for blank DVDs that you burn yourself. I don't know if your Alba will play them or not, but if you have only tried DVD-R, you should buy a few (as few as possible) DVD+R disks and burn one and see if your Alba will play it.
...and make sure you use bit setting on the LG4163B as "DVD-ROM" for +R discs...that should help with compatability problems...
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 03:09 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Would this DVD player play AVI files burnt onto a blank DVD/CD?
By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 19:38 -
Burnt DVD's consistently failing in standalone player
By otal in forum Newbie / General discussionsReplies: 10Last Post: 1st Feb 2008, 08:42 -
unable to play authored & burnt dvd on standalone player
By rancid in forum Authoring (DVD)Replies: 15Last Post: 10th Jan 2008, 20:24
