I've just got the above when I never have before.
I Multiplexing a VCD, using the MPEG-1 VCD setting.
I also tried the others and got more underflow.
Also, the resulting video looks a little slow motion.
The mpv video file was created with CCE SP, which never caused problems before. I ripped the audio from the original streaming AVIs using TMPGE.
One note is that the Multiplexing in TMPGE hasd worked before this (earlier in the day) without a flaw... ???
Thanks,
Troy
P.S. This problem was also mentioned before but no one seemed to have the answer:
https://www.videohelp.com/phpBB/viewtopic.php?topic=64835&forum=4&
As Peter said, probably you have chosen the wrong format. Try Video-CD(non-standard)
This may help or not. CCE produce very odd MPEG-1, especially at very low bitrates and VBR mode sometimes.
I guess, you try to multiplex your MPEG-1(multipass VBR).
Have a look at this topic:
https://www.videohelp.com/phpBB/viewtopic.php?topic=53352&forum=3
MuxMan : Buffer Underflow
By Bonie81 in forum Authoring (DVD)Replies: 3Last Post: 23rd Oct 2011, 15:38 -
Decoding and interpreting PSI sections split across TS packets
By Tuxdude in forum ProgrammingReplies: 0Last Post: 19th Sep 2011, 22:30 -
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 03:45 -
Warning : NAV Packets are not detected in video.mpg. Please demultiples
By anindyanuri in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2008, 21:38 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51
