I have problems playing back DVD's copied and converted with VSO DivxtoDVD Converter Program.![]()
Does anyone know if there is a way to open DVD Player Model DC-596M for playing with DIVX? Perhaps there is a code or something else?![]()
Thanks in advance for your help and advice.
Martha :-)
The dvd's created by VSO DivxtoDVD are no longer in dvix format, the software is converting them to DVD format mpeg2.
There is no way to update/modify a dvd player to play divx as it is a hardware feature that has to be built in. The player supports divx or it doesn't.Google is your Friend -
Thanks for your reply Krispy. But you see, even though the format is in DVD format mpeg2, I my DVD player does not support it, and I don't understand why it does not play it.
I played these DVD's in a Divx DVD player and it played them with no problem at all.
Therefore, my question is if there is a way to open my DVD Player Model DC-596M for playing the DVD format mpeg2?
Once again thanks for your help and guidance in this regard.Martha :-)
Sony DV Direct VHS to DVD Conversion Problem with Model VRD-MC6
By WRArtMonk in forum Newbie / General discussionsReplies: 19Last Post: 8th Dec 2012, 19:08 -
Problem with divx playback from media player to TV
By mcon in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2011, 12:06 -
philips 5982 divx playback problem
By wkk in forum DVD & Blu-ray PlayersReplies: 35Last Post: 26th Mar 2009, 13:56 -
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 13:17
