When trying to update the songs on my iPod using iTunes a keep getting, Attempting to copy to the disk [ipods name] failed. an unknown error occoured (-69)
Anybody know what could be causing this and how i can fix it?
Sounds like its time to either:
(a) Update the iPod's Firmware with the latest updater
or
(b) erase and re-install the the iPod's operating system.
error -69 points to:
Apple System Error Codes-69 badCksmErr addr mark checksum didn't check"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks terryj i did find the error codes but couldn't really make any sense out of it and how to solve the prolem, but the wierd thing was it seems to happens when i try to upload a certain song
A bad checksum happens because the device that
is being polled cannot properly " talk" at the moment,
and instead defaults to the error "bad checksum".
Could be that most likely it is a bad FW cable, but more often than not,
it is the FW port on the iPod that either needs to be reset
or updated via firmware to make it talk to the host device.
Don't fret it.
I've owned my iPod since 2002 ( a second gen 10GB)
and I've had to reformat it at least twice, to fix
a firewire issue.
it happens.
ipod/itunes problem
By angryassdrummer in forum Portable VideoReplies: 9Last Post: 10th Mar 2011, 11:57 -
Need Help With iTunes TV Show
By LegendaryLero in forum Newbie / General discussionsReplies: 6Last Post: 9th Feb 2011, 08:41 -
avi 2 itunes
By kg4886 in forum Newbie / General discussionsReplies: 4Last Post: 22nd May 2009, 05:29 -
Issue with ITunes
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 14th Feb 2009, 15:21 -
i have a problem with itunes?
By just in forum Off topicReplies: 0Last Post: 2nd Dec 2008, 17:02
