Now that I believe I found my perfect settings for video capture in VirtualDub I would like to save them for future sessions, but I can't find an option for saving capture settings. Can somebody please help me?
Thanks,
telerat
try file/save process settings
i dont cap with VDub so i dont know but i know it saves converting templates that way
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
I can't remember where but for each setting (audio, video, etc) there is an option that allows you to save it as the default setting. You might have to hunt with it to find out. It's been such a long time since I captures with VD that I can't remember how.
telerat,
Go to the "Capture" menu, and down to "Preferences..." The option to save your current settings is in there.
Now, if only it would remember the state of the Multi-Segment Capture option :/
VirtualDub question on huge file sizes, and save to formats
By etbrown4 in forum Newbie / General discussionsReplies: 10Last Post: 30th Sep 2011, 04:27 -
Is there a way to save a Virtualdub filter chain?
By groove365 in forum Capturing and VCRReplies: 5Last Post: 3rd Sep 2010, 23:20 -
VirtualDub....save as .mp4
By Ogilvy in forum Video ConversionReplies: 2Last Post: 19th Mar 2010, 23:29 -
Avidemux - Save settings?
By Shadarr in forum EditingReplies: 2Last Post: 15th Jun 2009, 10:19 -
Can VirtualDub save DV-AVI's?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 21st Oct 2008, 09:10
