    Aug 2005
    England
    I have 2 disks of the same film both in ts file format I have tried burning them with nero but with no success is there a programme where I can join both sets of ts files on to one DVD disk. Thanks
  2. Member MysticE's Avatar
    Nov 2003
    DVD2one has a handy join/merge function. You could also load all the VOB's into NeroVision Express, merge then chapter them. With NVE you will lose some quality when it re-encodes, and menus and subs though.
    Aug 2005
    England
    Thanks MysticE
    or tmpgenc dvd author and select add dvd video and select the video_ts. add both and make menu and author,burn.
    or dvdshrink, https://www.videohelp.com/guides.php?guideid=538&howtoselect=6;30#538
  5. ts files? Are you mean transport stream (ts) mpeg2 files?
