This is sort of weird. I have a few SVCD files that I downloaded from newsgroups and I wanted to make them smaller for saving to DVD (data) so I used QT Pro with DivX Pro (5.0.2 I believe) to "export" them. I set the bitrate to 2600 as the original MPEG2 file was at 2430 or so (as reported by ffmpegX) and I figured that would retain all of the quality without being so big. (the original file was 790 MB or so and I was hoping for 350 MB or so) It did a good job and after it was done I had a file that was 287 MB. I thought it was a bit small so I checked the bitrate in ffmpegX and it said the bitrate was 743! Does an SVCD "qualified" file lock in the bitrate or something? I've tried it a couple of times and get the same result each time, though later tries came up a little to 1130 or so. Need more info? Thanks.
Mac MDD DP 1.0 Gz.
1.75 GB
Lotsa disc space!
QT Pro 6
Results 1 to 1 of 1
Odd Audio Sync Problem
By Startropic1 in forum Video ConversionReplies: 0Last Post: 13th Aug 2010, 00:07 -
Hauppauge 150: Another Odd Problem
By Tom Saurus in forum Capturing and VCRReplies: 0Last Post: 12th Jun 2010, 11:22 -
odd frame rate problem
By deadrats in forum Video ConversionReplies: 0Last Post: 7th Dec 2008, 13:32 -
Odd problem? dv video disappears
By phorkster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 17th Sep 2008, 06:57 -
odd message from Toast while burning DIVX/XVID
By muttonhead in forum MacReplies: 6Last Post: 11th Sep 2008, 18:23
