I have been using TMPGEnc for some time now without problems. Recently I tried to convert an .avi file and got a message saying that the file type was unsupported. I can't figure out why since I've NEVER had a problem with converting .avi files before. So I used GSpot to find out the file info. All of my codecs are up to date, and everything seemed standard for an .avi file. Any suggestions as to why I can't encode this particular file?
According to GSpot it says the Video SRC Type is MP43 (S-Mpeg 4 Version 3) and that's about it. It says that the codecs needed to process this format are already on my computer. They are ffdshow Mpeg-4 Video Decoder and Morgan Stream Switcher. Does this help at all? As you can tell I'm very uninformed about this subject.
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 07:02 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
TMPGenc CAN NOT CONVERT AVI LF RT CHANNELS TO 2 AUDIOS
By suijaypao in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 05:03 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 00:21 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11
