  1. I have a video scene that is priceless and un-re-shootable.
    However, much to my dismay, when I watched it on my TV, I realized that there was a speck of dust or something on my lens while shooting. So it remains static thru out each frame.
    Is there some kind of way I can edit each and every frame?
    I could take each picture of the frame perhaps and edit this blotch out?
    It would be worth the headache.
    I have Pinnacle Studios 9 plus. I have Nero software too. But no idea how to even approach this dilemma.
    I beg of you to advise.
    Take care.
    Mar 2003
    Uranus
    VirtualDub will convert a video to billions of separate bitmap files - 1 for each frame and put them back together again later.
    What do you want to do with the speck ?
    There is a Vdub filter called Delogo which will blend an area to the surrounding colors all in 1 operation. Editing billions of frames is
    really not practical.
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    This is off topic but ...
    Holy crap FOO I haven't seen you around these parts in a long while. Glad to know you ain't dead LOL
    Time to re-do the AVATAR me thinks!
    As for the problem at hand the suggestion by FOO is probably best ... as FOO said there is a Logo Filter for VirtualDub as well as one for AviSynth.
    However the Logo Filter is not the only one you should try.
    For instance I once used an AviSynth filter called DeSpot that worked wonders on a VHS video capture that had a lot of static (poor cable TV reception). Another AviSynth filter that might work is called UnDot.
    You can find these two filters (and many more) at the following website ---> CLICK HERE
    Here is the AviSynth website URL ---> http://www.avisynth.org/
    - John "FulciLives" Coleman
  4. Thanks so much, guys. I will check out yallz suggestions.
    You guys simply rule and I really appreciate the lightning fast feedback.
    I'm stoked. Can't wait to try something at least.
    I just want to blend the dot in.
    It was a spur of the moment vid scene at a skateboard contest last night.
    A dude launched over two city trashcans stacked vertically. It was huge. I just happened to be there at the right time and got it, but that lousy little annoying 'UFO' flying above him (where I had got a speck on my fisheye lens).
    I thought about applying an old cinema filter to sorta mask it, but I'm looking into yalls suggestions first.
    Take care.
    Mar 2003
    Uranus
    off topic just this once.
    Greetings Fulci.
    No I aint dead - just smell that way.
    I been real busy and have lots of hobbies so I just lurk mostly.
