i need to get beta sp into final cut express hd
i have a guy with a digibeta sp with analog card but he thinks the beta sp will not play out the aes and sdi outs, then again he has never tried it.
anybodyu know if that will actually work? if it wont play beta sp's out he sdi, does anyone know a method to get it into dv? i assume that a component to dv converter will work if it exists.
thanks
Results 1 to 1 of 1
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 10:35 -
final cut to after effects
By thecrock in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2010, 19:34 -
ts / avi into final cut
By marinebc11 in forum MacReplies: 3Last Post: 12th Sep 2007, 09:58 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05
