I am trying to convert 4 divx files to vcd, then join them. my problem is, I load the file in tmpgenc and I get no audio, so I go to virtual dub to convert the audio from the wav file and save it as a seperate file so that I can use it with tmpgenc. problem is, I go to convert the audio to wav, and it says " the requested audio compression is not compatible with the input format. Check that the sample rate and channel count of the input match those of the requested format." then I click OK and another error pops up right after and says " AVIOutputWAV: The handle is invalid." the audio codec is AC3 I don't know where to get it or if I even need it. All help will be greatly appreciated! Thank you in advance!
Results 1 to 1 of 1
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 20:53 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
I have suddenly lost the ability to convert to DiVX with Virtual dub
By DaneClark in forum Video ConversionReplies: 6Last Post: 8th Jul 2009, 07:16 -
Error when trying to compress with Virtual Dub
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 7th Oct 2008, 13:39 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 11:56
