About a month ago, I purchased a Leadtek tv2000xp tv card for my home pc. After installing it, updating drivers, and getting my computer set up, I was watching tv with no problems. Then I tried to do what I had bought the card for and record. Records fine, except I get no sound when i go to play it back. I have tried changing settings after settings with no luck. Was wondering if anyone else ran into this, and if so, what they did to fix the problem.
(Dunno if this helps, but this is my system config)
Asus P5P800 Motherboard
Intel Pentium 4 630 Prescott 800MHz FSB LGA 775 EM64T (3.0 ghz)
1 gig of ddr 2700 memory
200gb wd HD 7200rpm 8mb cache
ATI Radeon 9700 Pro AGP
Leadtek tv2000xp expert
DVD Rom
Sony DVD Burner
Software that came with it is:
Video Studio 8.0 from Ulead
Cool 3D 3.0 from Ulead
WinFastDVD from Leadtek
Any help or ideas would be greatly appreciated. Thanks
Verify the "Audio Recording Line" setting in the Configuration dialog box of WinFast PVR.
Your card has no audio recording capabilities (it sends the audio to your SOUND CARD). Get the program VirtualVCR and record with this. Once you get the proper audio path figured out, you'll never have to change it (and it always works).
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I will have to give that a try when I get home from work. Will also have to see if the recording scheduler that works with my current video software will work with virtualvcr, but if not I will figure out another way.
In case anyone else runs into this, I found a way to use the included software for tv2000xp expert to record sound as well. http://www.leadtek.com.tw/eng/support/faq/FAQ_How_to_setup_the_audio_of_my_TV2000_XP_E...ert_112204.pdf
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Recording pc video/audio out to itself - how do I avoid audio reverb?
By yoda313 in forum Capturing and VCRReplies: 4Last Post: 18th Feb 2008, 20:27 -
Making a comp and having some problems need some expert help
By moviedude2525 in forum Authoring (DVD)Replies: 1Last Post: 22nd Oct 2007, 18:03 -
What is better than a leadtek expert tv tuner card?
By Gplracer in forum Capturing and VCRReplies: 1Last Post: 7th Jul 2007, 14:44
