Have three quick questions.
1. Want to convert avi to dvd. Is it alright if I choose mpeg2 as the output file format? I'd choose dvd but in this encoder, choosing dvd as the output format doesn't allow me to use the 3:2 pulldown option. Can use 3:2 with mpeg2 though.
2. For some reason, after I encode with mpeg2 as the output file format, the final output file size is 1.92gb. But the estimated final output file size determined by the encoder is 4.2gb. Why isn't the output file size 4.2gb?!
3. Does it matter if the final output file size is, for example, 2gb or 4gb when it comes to video quality?
Can't be sure, but selecting DVD for output probably puts pulldown in automatically.
What are your encoding settings ? CBR or VBR ? One pass or two ? Bitrate ? Details man, details !
If the bitrate is too low, the quality will suffer. Size is determined by bitrate x running time. What is the bitrate and what is the length ?
Your questions are the equivilent of asking a mechanic "my vehicles makes a noise, is this right ?". He will want to know what type of vehicle, what type of noise. If you wan't detailed and corect answers, you have to ask detailed and correct questions.Read my blog here.
Was gonna add details, but didn't know what details to add! Sorry about that.
I checked the pulldown when selecting DVD for output. It just says, 'Pulldown = none'Originally Posted by guns1inger
using VBR, 2 pass, bitrate:Originally Posted by guns1inger
max kbps = 8000
ave kbps = 6102
min kbps = 2500
length of film = 1h 36mins 21secsOriginally Posted by guns1inger
Here are some pics so you get a better idea:
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
Final Cut Pro 5/File quality and conversion questions to .avi
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 21:24 -
MainConcept H.264 frame rate issues encoding Final Cut output
By soandso in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 13:46 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 04:08 -
Encoding 720p MJPEG file using Mainconcept encoder --> for Streaming vid
By Mysteriouskk in forum Video ConversionReplies: 3Last Post: 25th Nov 2007, 04:39
