i follow exactly the guide below but the output file is bigger than 700mb CD. my movies is 1hr 32mins and the resolution is 640x352 .
http://web.telia.com/~u31220486/dvd2avi/dvd2avi.htm
please help
Results 1 to 10 of 10
Depends on how much bigger. You can get 830Mb on a 700Mb CD if you burn it as an image file. DVDDecrypter can burn images or even Nero.
If your tutorial doesn't tell you how, you could use a program like Folder2ISO to create an image file that DVDDecrypter can burn. Or you could use 'overburn' with a program like Nero if it's just a little larger than your CD size, though this method is less dependable.
BTW, I use Fairuse Wizard for DVD to Xvid. Very easy to use if you want to try a different program. -
i follow the guide as the first time i encode 720x480 and the output file is around 1.6gig. i tried to lower resolution to 640x352 and output file is 745mb. the Virtualbud calculated the output file for 700mb but i don't know why. the output quality is awesome very clear and run so smooth.
i'll try the Fairuse Wizard. hopefully it won't exceed 700mb CD like the program above and output quality is not too bad.
thanks redwudz -
Originally Posted by vgt"Art is making something out of nothing and selling it." - Frank Zappa
Originally Posted by ZippyP.
Did you figure in the size of the audio? Did you figure in the overhead (not much)?
now another problem with Fairuse Wizard (turorial http://www.dvd-guides.com/content/view/34/59/ )
after i RIP the DVD to the HD (step 4 in the tutorial ) then the program closed by itself. i tried to open it as Open an existing project but the same problem. i can't go to step 5.
the program closed right here in few seconds after click next. it came up a screen as the image below then it gone.
http://img210.imageshack.us/img210/7046/14yw1.gif
here's what i got at the step 4. what did i do wrong ?
where buddy ? in the virtualdub ?
You don't enter 716800 in VDub. You enter 716800 minus the size of the audio, minus the size of the muxing overhead.
Can't help with Fairuse. I recommend AutoGK.
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 17:25 -
why is the output bigger
By rusty666 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2011, 05:50 -
ISO file bigger than original video_ts file.
By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 19:04 -
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 20:55 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22
