  1. Member dragon_1's Avatar
    Jul 2005
    i don't know
    Does DVDFab Decrypter split iso files into 1GB chucks like DVD Decrypter and DVD Shrink? Becuz i'm running on win ME
    Sorry if this has been posted before
    USA
    The basic version (DVDFab Decrypter) does, as that is the DVD specification for VOB size.
    DVDDecrypter has a setting for 'File Splitting' in IFO mode where you can set it to one large file. This should be handy for converting to Xvid or other formats that don't need VOBs. Looks like you can do the same in File Mode by adjusting the File Splitting size to none. I haven't used either of these settings, though. Give it a try.
    EDIT: I may have misread your question. The individual files within the ISO or the file would be 1Gb. You wouldn't want a bunch of 1Gb ISO files. I suspect one of the reasons for 1Gb VOBs is because of the FAT32 limitations. I haven't used an ISO with a FAT32 OS, so not sure about large ISOs.
  3. Member dragon_1's Avatar
    Jul 2005
    i don't know
    ThanX for the help but DVDFab Decrypter does split the iso files! Yay, i tested it on a DVD that i own thanX anyways
