i,ve been using this prog for a few months now,but now having a problem joining files,when clicking on 'make quick dvd' it now comes up with 'two title sets' anyway what happens is that it only seems to burn the first file,i did'nt have this problem b4 just recent,i've looked through the options and tried a couple of thing but to no avail,also i've seen in another thread about joining the two rar files (how do i do this),which is the better option?,i know its probebly something simple but i carnt figure it.
thanks
chezuk.....
Can you post your log file?
Ok. When using "Quick DVD", SVCD2DVD will try to work out how the DVD should be laid out in terms of TitleSets.
It does this by considering Asset files from different folders to be from different movies (and so will create new TitleSets for each folder your assets are in). Also if your Assets have different basenames it will assume a new movie (and TitleSet) too.
I.e.:
Will create two TitleSets: one containg the files from FolderA and one containing the files from FolderB.Code:FolderA\movie1a.mpg FolderA\movie1b.mpg FolderA\movie1c.mpg FolderB\movie2a.mpg FolderB\movie2b.mpg FolderB\movie2c.mpg
Would create three TitleSets as there is no common basename in the files in FolderA.Code:FolderA\movie2a.mpg FolderA\Film2a.mpg FolderA\Capture2a.mpg
If you start with BIN files:
You may have:
And expect to get a Single TitleSet. In most cases this will be true. However if moviePartA.bin contains 2 mpegs and moviePartB.bin contains a single mpeg then the mpeg filenames may not have a common base name. It is in these cases that you may not get what you expect....Code:FolderA\moviePartA.bin FolderA\moviePartB.bin
Thus, in such cases, SVCD2DVD tells you that you have more then one TitleSet. It is now up to you how to procede. You can delete the second TitleSet and just make sure your mpeg Assets are in the first TitleSet (in the order you would like).
Of course you can set things up manually - it take seconds - and you will never get anything you don't anticipate.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
thanks chrissyboy,
i'll check when i get home
iknow the two bin files i have only contain 1 file each,and i'm sure the names are the same just with a different number at the end of the file name.
i'll have to c if i can see an help file for manually setting it up on this new version of svcd2dvd -
ok. Let me know how you get on (email me your log file if you want). Here is the demo movie for Manual Layout: http://software.badgerit.com/SVCD2DVD/DemoMovies/ManualLayout.htm
Help Joining Two .srt Files As One
By bigb_y2g in forum EditingReplies: 18Last Post: 6th Nov 2015, 10:07 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 13:52 -
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 21:33 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 21st May 2009, 00:03 -
Problem Joining AVI files with MEncoder
By RetSpec in forum EditingReplies: 1Last Post: 6th May 2007, 23:00
