  1. Hi there
    When i try to play a video (any format, avi, mpeg, dvd, wmv), they doesn't play UNLESS i right click over the video and click "Play on my tv".
    When i do that it opens in the windows media player and then i can play any video with any other tool.
    If I just open the video with other tool it doesn't work.
    Plus, sometimes it auto-fill the screen (full screen) and i can't exit/forward/change chapters/etc. To leave the video i have to press alt+f4
    Why is that happening?
    Might be an influence of codecs?
    Videocard configuration? (G-Force XFX 5200 256mb) What i dont think so because it was working pretty well before i format my hd
    please help me!
    Rodrigo
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Do you have a capture/TV card installed? TV playing software? Sounds like something changed the file associations of your video files. Try opening WMP, go to view/ options/ formats and click the "select all" option.
    Google is your Friend
