Just load this software on my computer. When I run the exe file it takes a very long time to come up. After it is up I select Avi to DVD and add an avi file. At that point the program crashes. Seems like it is looking for something and can't find it to process the file.
I unstalled it and tried version 6.33 with the same exact results.
Any suggestions??
I have the latest version (now 7.03) and it loaded just fine for me. I would recommend uninstalling the old one and then going tothe cucusoft site and downloading the one from the members only area and givign that a go.
I have been able to use my latest version. The only "weird" thing is that I get more settings options (I bought the lite version) in the X.0 versions. I am able to set the fps and other stuff. It works pretty well for some stuff, but I noticed sync issues that I dont see with TMPGENC encoder (bundled with dvd author). I have been EXTREMELY impressed with it. -
I will give that a try, had not thought about getting 03. I did find and correct my original problem but thanks for the reply.
cucusoft video converter software help
By goatroper57 in forum Video ConversionReplies: 6Last Post: 1st Jan 2012, 21:42 -
DVD Ripping problems with cucusoft
By oki4life in forum DVD RippingReplies: 1Last Post: 27th Nov 2011, 18:44 -
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 15:57 -
CUCUSOFT file conversion issue
By steve7510 in forum Video ConversionReplies: 3Last Post: 16th Jun 2007, 09:21 -
By steve7510 in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2007, 22:05
