I made a DVD with NeoDVD4 from a wmv file 640x480, 400kbps, audio sample 16 bit, audio sample rate 48HZ, video data rate 327kbps, video sample rate 24 bit. The video and audio were out of synch.
I made the same DVD with Sonic myDVD 4.5 and there were no synch problems.
Can anyone tell me how to make a wmv file so that it won't have synch problems with any DVD buring software? (I'm uploading the videos to the web and don't have any control over what program people will use to make the DVD)
Thanks,
George
If there are no sync problems with the WMV file then its the method of re-encoding that caused the problem, you can't make a wmv file that won't have sync probs with all dvd burning tools as its down to the re-encoder of those tools that determine the output of the conversion and is therefore out of your control.
The only way others will get a dvd from your wmv file thats in sync is by said people using a decent re-encoder such as TMPGenc, ... i have no probs converting WMV files to dvd complient Mpegs using TMPGenc express and then authoring to DVD with TMPG dvd author
How to fix audio synch problem in AVI file
By vertical in forum Newbie / General discussionsReplies: 153Last Post: 20th Aug 2021, 07:45 -
Codec problem in ASF/wmv file (wvc1)
By ezzeee1 in forum EditingReplies: 7Last Post: 25th Feb 2011, 21:16 -
Making a 1 gig HD wmv file to smaller portions
By OzzyWeb in forum Video ConversionReplies: 5Last Post: 28th Mar 2010, 12:10 -
Problem converting .wmv file
By AdamUK in forum MacReplies: 3Last Post: 24th Apr 2008, 08:40 -
WMV Conversion to Xvid - Audio Synch Problems Again
By TonyRomo1227 in forum Video ConversionReplies: 10Last Post: 6th Aug 2007, 17:32
