  1. hi,
    My videos in DV AVI format look just fine, but when i convert to MPEG2 DVD they become very shakey and look as if I was shaking my camera all over the place. Very jerky. Also the shaking seems to make the vid lose quality and get blurry.
    I know its got something to do with the frames, I have tryed top and botom field order, it deosn't seem to matter. I've tryed a few different programs to convert as well Ulead DVD Movie Factory, TMPGEnc and I downloaded a few other programs as well, i get the same effect every time.
    I am using a pinhole lense which I believe is causing this to happen becuase it never used to do this, but the DVs look fine so I'm hoping there is a way to fix this.
    Any suggestions?
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    If the DV looks fine, it's not your pinhole lens. Offhand, it sounds like you need more bitrate.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    it sounds like field order, but some screen shots would help
    Read my blog here.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Did you try encoding the transferred DV with Ulead DVD Movie Factory and creating the DVD there?
    Your problem is in your procedure.
    http://www.kiva.org/about
  5. Originally Posted by zoobie
    Trust me its the lense. I'm not an expert at this stuff but i know when I used to use the cam by itself I never had this problem.
    For one thing pinhole lenses inverts the screen, so the cam needs to be upside down. I also need to turn "Steady Shot" off on my Sony cam because it seems to reverse that setting as well.
    All i can say is the Dv will look ok, then when I make MPEG2s itlooks like the cam is shaking alot more, like it was 2 different videos all together
    I used to do it that way, then started editing my DVs in VD because it was easier. I leave the DV interlaced. Then I have tryed using different programs (I usaully use Ulead) as I mentioned and used top and bottom field order, and it always comes out the same.
    When the movies are interlaced they look ok, but once I encode them to MPEG2 thats when the shake happens
    I've also captured using WinDv as well, same story.
  6. Member edDV's Avatar
    Mar 2004
    If it looks OK after transfer and before encoding then it would seem to point to your encoder settings. If you could post a representative frame capture we would recognize the issue. "Shakey" and "two pictures" usually points to field order as said.
  7. EdDv I sent you a PM
