Hi,
When you choose the pre-set in ffmpegx for MP4 h.264 video...the settings suggests a bitrate for the video under the video tab and under the option tab contant bitrate is checked.
Does this mean that it will in fact encode the entire video at the suggested rate in the video tab? If so...if I change that rate will it encode at what I specify?
Thanks,
John
Results 1 to 9 of 9
How do you control file size then when using variable bit rate? Is it that ffmpegx uses the best bitrate for the source as it goes along trying to optimize both quality and file size?Originally Posted by major
-john
When using variable bitrate, the size is unpredictable, as the encoding is done in constant quality, and the size is free to vary to fit movie complexity. You can however control the compression level (leading to bigger or smaller files) with the quantizer. Lower qmin=qmax is higher quality and bigger files.
Can you reduce video (MKV/H.264) Bitrate withOUT re-encoding?
By KushSmoka420 in forum Video ConversionReplies: 4Last Post: 14th Mar 2012, 05:17 -
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 08:49 -
Both constant bitrate and two press bitrate are the same,right?
By tendra in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 05:35 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 07:38 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 18th Oct 2007, 00:56
