    Dec 2001
    Hong Kong
    RT2000 separated the avi to max. 2.0G files. Please anyone help me to make a VCD by using TMPGRnc or other free software. Thanks.
    Granville
  2. Granville,
    I don't even know what's your problem! Are you just don't know how to encode the avi and burn as vcd? If so, go to the left and read the instructions. Jordan
    Dec 2001
    Hong Kong
    Sir, thanks for your help. My problem is that RT2000 will create a RT2000 project file, in which RT2000 cut the avi (e.g 5G) to be separated max. 2G avi files. (2 x 2G avi files and 1 x 1G avi file). How can I do to let TMPGEnc make vcd from RT2000 file.
    Granville
  4. If I understand you correctly, your problem is that your source is a segmented AVI. In that case, your best bet is to load the segments into VirtualDub (or AVIsynth, if you are comfortable with a little more advanced process) and frameserve it to TMPGEnc.
    Dec 2001
    Hong Kong
    Yes, it is the natural of RT-2000 file. The problem is how can I do. Any software or procedure you can teach me?
  6. Does RT-2000 produce actual AVI file segments, or some sort of proprietary format? If they are AVIs, use the procedure I outlined previously of loading those AVI segments into VirtualDub and then frameserving them to your encoder.
    Jul 2001
    Indonesia
    or..... change to w2k,so you can make unlimited .avi size
