im using tmpgenc to encode a working (works using wmp) avi into a kvcd file format using a template the strange thing is that the exact same template works with all my other videos i also used video fixer to try and solve the problem but to no avail can anyone give me some ideas on what to try next?
So AC3 audio. Well if you didn't have a decoder installed then TMPGEnc simply would have not loaded the avi as an audio source (something that I would hope people would notice), if you did have one installed then it should have loaded and converted fine.
I thought that KVCD templates were video only anyway?
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 22:10 -
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 06:51 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 17:12 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 11:18
