Just upgraded to the latest version and now keep getting the following error, if i click continue the error re-appears every 10 seconds:
Didnt get this error with the previous full version or the demo version.
Help
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040154): COM object with CLSID {4590F811-1D3A-11D0-891F-00AA004B2E24} is either not valid or not registered.
at System.Management.ManagementScope.Initialize()
at System.Management.ManagementObjectSearcher.Initial ize()
at System.Management.ManagementObjectSearcher.Get()
at xa3b71f2e66c561c8.x54459e65bed47b30.GetInstances(M anagementScope x38879776c2e6a3fc, String x29ca7772d281a736, String[] xa145a0cd0b452e9c)
at xa3b71f2e66c561c8.x54459e65bed47b30.GetInstances(S tring x29ca7772d281a736)
at x3284ccece41ee22b.x210ff09a2516b1a7.x49062ce067e29 c80(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.2110.33884
Win32 Version: 2.0.2110.33884
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
DevComponents.DotNetBar
Assembly Version: 5.0.0.0
Win32 Version: 5.1.1.7
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Can you redownload? This should be fixed.
C,,
Sometimes, windows is full of features. You can help yourself by trying to maintain all the basic layout. When you want to close the app, &File E&xit, and so on. Let say that the basic form of dialog is your first best interface, use that. Use Hints that shorten learning ... shortcuts ... and use the drop and drag or extensions to users or add right click features. Your net interface is nice but stay to windows directlikeness, it will insure you get the best uses of programming api's. I know it's boring. You have great potential. Some people get stranded fast.Programming not so hard if you try. Systems won't work the way you want. Sense isn't for an Analyst to grasp. -
I noticed that the SDE Patch says, "200% done." or "32,500% done." When it happens I think it is a leak and it happened somewhere in a registered component. If I processed right, the video was not displayed right on the viewing during playback on my TV. I thought I might have to reboot, eachtime that is, to get the processing not to fail.
If you have an issue, start a new topic. This one was wrapped up.
Latest version of Google Earth?
By alegator in forum ComputerReplies: 2Last Post: 15th Feb 2010, 19:38 -
what is the latest version for quicktime ???
By khalid81 in forum Software PlayingReplies: 2Last Post: 10th Jun 2009, 18:40 -
Latest Version of VLC
By Wanderlustus in forum Software PlayingReplies: 6Last Post: 20th Feb 2009, 13:47 -
Possible bug in latest version of GUI for dvdauthor
By boweng in forum Authoring (DVD)Replies: 10Last Post: 3rd Mar 2008, 06:22 -
Question re updating to latest version svcd2dvd
By Lord Flange in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 11th Oct 2007, 19:04
