  1. Hi! I just got the Creative Video Blaster and I was wondering something. I know I can convert a mpeg-1 to VCD, but my question is: Can I do the same with a mpet-2? I mean turn a mpeg-2 to VCD? If yes, what program should I use?
    Thx in advance...
  2. Basicly yes, you can load your MPEG2 file in TMPGEnc, load a VCD Template and Encode, it will create a MPEG1 out of your MPEG2.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. Thx Sefy! But is this worth while! Will I see a difference?
    p.s.: I'm transfering old home videos
  4. Actually, I don't think it's worth it, mostly because re-encoding will always reduce quality, so it's not recommanded
    Best Regards,
    Sefy Levy,
  5. Ok! Thx a lot. I will do as you said... Thx again for the fast reply...
