I've just learnt how to frameserve VOBs to TMPGenc Plus for encoding to m2v files for use in DVDLab, but the resultant DVD tends to stutter on fast action scenes.
I tend to lower the bitrate in TMPGenc so I can fit more files on a disc - I'm prepared to accept a small ammount of blockyness on fast action scenes. I've made plenty of DVDs from AVI files that worked fine with no stutter - but now I'm frameserving, this problem crops up.
The software I use:
DVD Decryptor for ripping
DVD Shrink for extracting individual VOB episodes from the ripped disc
DVD2AVI to create the frameserving file
TMPGenc Plus to convert the VOB via frameserving to m2v format
DVDLab to author the DVD
DVD Santa to burn the disc
I'm ripping PAL DVDs and making PAL discs, so I don't need to convert framerates.
Would it be easier to save out the VOBs in a compressed format with DVD Shrink, or would the picture quality suffer? At least I could bypass the TMPGenc phase if I used this method.
Top field first is the more common DVD order.
Test by frameserving your encoded video to Virtualdub, then step through action scenes and check for "step-backs".ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Ah - I get a bit lost frameserving to Virtualdub. Not too sure how to do it! lol
I'm currently trying a test encode in TMPGemc using top field first, so I'll see how that goes.
Lg-bd630 stutter problem solved!
By RogerTango in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Feb 2012, 15:18 -
Video stutter problem
By teg in forum Software PlayingReplies: 15Last Post: 28th Jan 2011, 19:06 -
newbie,i have a problem,i burn a dvd on playback i get stutter when panning
By goldenbhoy in forum Newbie / General discussionsReplies: 10Last Post: 28th Apr 2008, 15:00 -
TV capture stutter problem
By altos in forum Capturing and VCRReplies: 4Last Post: 24th Jun 2007, 13:09 -
DVD RB stutter
By jm in forum DVD RippingReplies: 6Last Post: 12th May 2007, 23:32
